2 minutes ago, turismotom100000 said:
I have a b450 Tomahawk max mother. Just installed a m.2 drive not recognising hard drives
Any help please
When an M.2 drive is installed 2 of the 6 SATA ports are disabled, connect your hard drives to different SATA ports. Check the manual for more info on this.
https://linustechtips.com/topic/1286776-m2-problem/#findComment-14339758
37 minutes ago, AndreiArgeanu said:
Here's the snippet from the manual. The second photo is which sata ports are which on the motherboard.
image.png.ace2a6fb4c646ac038b471b60a6dd4d4.pngimage.png.67abc2d728ed96355506fdf79cb2b7f5.png
Thanks for your help switch them about and they are all recognised. Just first time using a m.2 nvme gen 3 drive use to normal sata ssd can definitely tell the difference
https://linustechtips.com/topic/1286776-m2-problem/#findComment-14339854
