GPU HELP!!
Go to solution Solved by Applefreak,
6 minutes ago, Dannyuscg said:
Budget (including currency): $400 US
Country: USA
Games, programs or workloads that it will be used for: flight simulator, COD, FORTNITE and others in this category.
Other details I got my son a pre-built gaming PC for Christmas. I was on a low budget but, after reading about how good Ryzen 5 3600 6 core was, I pick this PC. Its playing good now for what it is but its taking a long time for flight simulator to load. The game will play and so far, only crashed maybe twice. I know a little about computers and components but not enough to figure out what will be a best pair to match together. Im thinking I need a better graphic card. I have a, amd radeon 570 gpu now and thinking I need to upgrade it along with increasing the 8gp of ram to 32. Thanks for the help.
What make and model is you pc? You won't need 32 GB of ram. 16 would be fine as well. The GPU should be able to handle the game if you pace yourself with graphics settings. The game should be run off a SSD. That will improve load times as well as fps.
Country: USA
https://linustechtips.com/topic/1286401-gpu-help/
What kind of drive does the computer have? That's what affects loading speeds.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/1286401-gpu-help/#findComment-14337165
Country: USA
https://linustechtips.com/topic/1286401-gpu-help/#findComment-14337169
The rtx 3060ti fe is a good card if you can get it at msrp (your current gpu should be fine though) but if loading times are an issue a 16gb kit of 3200mhz ram pairs well with a ryzen 5 3600 and  costs around $50. A ssd would also increase loading speeds and you should beable to find a 1tb nvme m.2 ssd for under $100 and a 500gb one for under $50
https://linustechtips.com/topic/1286401-gpu-help/#findComment-14337195
CyberPowerPC - Gamer Master Gaming Desktop - AMD Ryzen 5 3600 - 8GB Memory - AMD Radeon RX 580 - 2TB HDD + 240GB SSD
https://linustechtips.com/topic/1286401-gpu-help/#findComment-14337399
https://linustechtips.com/topic/1286401-gpu-help/#findComment-14337475
