Got new parts, put it together, no post. I have switched out the motherboard and CPU. The EZ debug light says CPU. I bought a new PSU, maybe thinking I needed to make it have it’s overclocking port as well. Tried 1 stick of ram, flashing bios. I did notice something though. If the GPU isn’t in the PCIE slot, it still says CPU, even when it’s plugged in.
MoBo: MSI MAG x570 Tomahawk WiFi
CPU: Ryzen 7 3700x
GPU: RX 580 Armor OC
Ram; G. Skill Trident Z RGB ram
PSU: Corsair RM 650
Cooler: Standard Wraith cooler that comes with the Ryzen 7 3700x
I am staring to get frustrated with this.
Did a BIOS update on the old board. Haven’t done it with the newone since it says it’s out of the box comparable. Tried 1 stick of ram. Tried Re-seating.
https://linustechtips.com/topic/1286358-pc-won%E2%80%99t-post/
Do you have any way to check that your CPU is indeed working?
Did you connect the CPU power on the motherboard (usually top left corner)
CPU: Ryzen 5 3600 @ 4.4GHz 1.2v / GPU: MSI Radeon RX 5700 Mech OC GP (5700XT Bios) @ 2GHz / MB: Asus ROG Strix B450-F / RAM: Kingston HyperX 16GB DDR4 3200MHz CL16 / CASE: MSI MAG Vampiric 010X
https://linustechtips.com/topic/1286358-pc-won%E2%80%99t-post/#findComment-14336968
Yup.
Don’t have anyway to see if it’s working, but i had bought a new one and it still didn’t work.
https://linustechtips.com/topic/1286358-pc-won%E2%80%99t-post/#findComment-14336971
Just now, ih8everything said:
Yup.
So you had two 3700x?
If you have tried two CPU's and its still not working chances are that the problem is the motherboard.
https://linustechtips.com/topic/1286358-pc-won%E2%80%99t-post/#findComment-14336974
So you tried two different motherboards and two different cpus?
https://linustechtips.com/topic/1286358-pc-won%E2%80%99t-post/#findComment-14337000
Yes. There’s a light that lights up “CPU” which means it’s not detected or it failing. I first thought it was the CPU, but it wasn’t, So i thought maybe the Motherboard CPU slot was bad, but the light still shows up.
https://linustechtips.com/topic/1286358-pc-won%E2%80%99t-post/#findComment-14337002
Then I would give it a try to updating the BIOS on the newer one even tho it says its out of the box compatible.
https://linustechtips.com/topic/1286358-pc-won%E2%80%99t-post/#findComment-14337013
