Fan advice (140 vs 200mm)
NorKris
Hi
What type of fan would you go for as intake fans? I have a H500m with 2x https://www.amazon.ca/Cooler-Master-R4-200R-08FC-R1-MF200R-Airflow/dp/B0787G3W1K as intakes.
but now I have 3x HD140 RBB fans from corsair.
the stocks fans are "loud" at around 600 RPM and the HD140 are loud at around 930+ RPM.
what fan setup do you guys think gives me the most CFM in total?
TY-143 😄
Great fan, but a bit loud after 1600rpm..
Probably not what your looking for.. but if you want some extra airflow.. it’s got it 😄
AMD R7 5800X3D | Thermalright Aqua Elite 360, 3x TL-B12, 2x TL-K12
Asus Crosshair VIII Dark Hero | 32GB G.Skill Trident Z @ 3733C14
Zotac 4070 Ti Trinity OC @ 3045/1495 | WD SN850, SN850X
Seasonic Vertex GX-1000 | Fractal Torrent Compact, 2x TL-B14
