Okay, so i have some question.. is it possible to connect more fan i mean if you don't have any 3/4 pin left on your motherboard
and how do i extend short fan cable such as the Corsair SP 120mm
Thanks...
Processor - Intel core I7 3770k 3.50 GHz
Graphic Card - EVGA GTX 670 (2 GB)
Motherboard - Asus Maximus V Gene
Corsair H100i
Ram -Corsair vengeance (8 GB)
SSD Samsung Pro 840 (GB256)
https://linustechtips.com/topic/12858-fan-connector/
If you don't have any 3/4PIN headers on your motherboard, you can connect your fans using 3PIN - Molex adapters. This means your fans will be running at 12V (100%) all the time. To extend your fan cables, you can buy 3pin - 3pin fan extensions.
https://linustechtips.com/topic/12858-fan-connector/#findComment-137214
So It mean Is possible to connect 3 fan with 3 pin connector, for example one side of the cable has 3 pink and other side has 3 cable each one has 3 pin right ? like in the picture ....
Hard to decipher exactly what you're asking; however, i presume you mean that is it possible to connect 3 fans to one 3pin header - as the picture shows? If that is what you're asking, then yes. It is possible.
https://linustechtips.com/topic/12858-fan-connector/#findComment-137513
I suggest that you get a fan speed controller for your 5.25 in bay or get a splitter.
CPU: i5 -2400 Cooler: Noctua NH-L12 Mobo: Fatal1ty Z68 Pro Gen3 Memory: Corsair Vengeance 8gb 1600mhz SSD: Samsung 840 120gb HDD: WD 3TB Green, Seagate Barracuda 1TB GPU: Asus GTX 760 Direct CU II (future SLI) Sound card: Xonar Phoebus PSU: Corsair RM series 750 watts Case: Aerocool Mechatron Fans: Bit Fenix Spectre Pros
Monitor:Samsung SyncMaster SA950, Philips Blade 234CLSpeakers: Logitech z506 Headset: Razer Tiamat 7.1 KB: Blackwidow Ultimate Stealth edition Mouse: Ouroburos Mouse pad: Golaithus Extended Speed edition Gamepad: Orbweaver Controllers: Wireless Xbox 360 Controller, Razer Hydra
System: Razer Edge Mouse: Razer Orochi Mouse pad: Razer Vespula Controlers: Razer Sabertooth (2 pcs.) Headset: Razer Blackshark Speakers: Razer Ferox What can I say, I'm a huge fan of Razer.  :D
https://linustechtips.com/topic/12858-fan-connector/#findComment-137547
Yeah Exactly That what i meant To Connect 3 fan Into One 4 pin cable... but how do the asus xpert
 Software will know that i connected 3 fan into one 3 pin and change their RPM...
https://linustechtips.com/topic/12858-fan-connector/#findComment-140749
I think Fan Xpert will either not work controlling the 3 fans or they will be all running the same speed and the fans will be running on the same fan curve. Check your fan current ratings on your motherboards and fans to see if the header supports 3 fans.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/12858-fan-connector/#findComment-142702
