Temperature questions: I'm playing Cyberpunk with High settings and Medium RTX, forgot to turn on DLSS and my i7 10700k got up to 87C.
Solved by Yebi,
It is technically safe, as in it's not going to be killed by that. It is high though, meaning it's gonna run slower than it could. Looking at the long-term, the lifespan could be affected by high temperatures, but that's more of a theoretical thing rather than something you should actually worry about.
I doubt it has much to do with DLSS, or other GPU settings for that matter
What kind of cooler, case, and case fan configuration do you have? When was the last time you cleaned the CPU heatsink?
