Shift-Enter for submit edit doesn't work
Go to solution Solved by Spotty,
1 minute ago, pythonmegapixel said:
What did you expect to happen? Pressing Shift+Enter would submit the edit, the same as when making a new thread or a new reply to a thread
Shift + Enter does not submit the post. It will start a new line.
CTRL + Enter submits the post. It works for both new posts and for editing existing posts.
Browser, version and OS: Firefox 82, Ubuntu 18.04 (oops, looks like Firefox is a bit out of date, better update it, but I digress)
Steps to reproduce/what were you doing before it happened? Editing a post, pressed Shift+Enter
What happened? A new line was inserted in the post.
____________________________________________________________________________________________________________________________________
pythonmegapixel
into tech, public transport and architecture // amateur programmer // youtuber // beginner photographer
Thanks for reading all this by the way!
By the way, my desktop is a docked laptop. Get over it, No seriously, I have an exterrnal monitor, keyboard, mouse, headset, ethernet and cooling fans all connected. Using it feels no different to a desktop, it works for several hours if the power goes out, and disconnecting just a few cables gives me something I can take on the go. There's enough power for all games I play and it even copes with basic (and some not-so-basic) video editing. Give it a go - you might just love it.
https://linustechtips.com/topic/1285694-shift-enter-for-submit-edit-doesnt-work/
*facepalm*
Yes, you're absolutely right. I'm an idiot...
pythonmegapixel
Guest
