Budget (including currency): $900us
Country: United States
Games, programs or workloads that it will be used for: call of duty, PUBG, other first person shooters
All that I need is a GPU, CPU and a CPU cooler
https://linustechtips.com/topic/1285665-my-first-pc-build/
get a rtx 2060, if you demand higher fps or monitor resolutions etc go for a rtx 3070
https://linustechtips.com/topic/1285665-my-first-pc-build/#findComment-14332854
8 hours ago, Chris Fortune said:
Is the budget for just what you need or does it include the items you already have?
Also without a PSU you will have a flashy paperweight
Well since this is 2020 I will have to wait a little longer to get my PSU due too finances. Emergency came up and had to use the remainder of my budget. But I’m looking to get the Ryzen 9 in the beginning of the new year.
https://linustechtips.com/topic/1285665-my-first-pc-build/#findComment-14333502
I will be getting a RTX 3070, unfortunately everything is sold out. I did find a guy close to where I live that is selling a EVGA RTX 3070 XC3 Ultra edition for $750.
Should I wait till GPU’s are back in stock?
Or should I buy that one?
https://linustechtips.com/topic/1285665-my-first-pc-build/#findComment-14333511
Here in the UK although it is patchy GPU stocks are retuning but I would not suggest they are anywhere near normal, that said if you will be needing a CPU and PSU both of which are also tricky to source then what's the rush.
Short version I would wait.
https://linustechtips.com/topic/1285665-my-first-pc-build/#findComment-14333970
wait if u dont want to spend 200 dollars extra
https://linustechtips.com/topic/1285665-my-first-pc-build/#findComment-14336097
