New build will not POST
Update 28/12/2020: Turns out the way the hard drive was mounted to the hard drive cage was the issue and not the PSU. The screws at the bottom of the H510 hard drive cage was touching the PCB of the hard drive and causing a short, triggering the PSU's short circuit protection. Mistake on my part, but the H510 HDD installation instructions aren't very detailed (they literally just show you a single picture of the blown up HDD cage showing where the screws go). Dead hard drive later (though I managed to get a replacement), my PC is up and running! Wow what a journey trying to diagnose the issue!!
Yeap, so I've tried testing the PSU with the paperclip method (connecting pin 15 and 16), ensured that I've turned hybrid mode OFF to see if the PSU fan spins and connected the hard drive to see if it will spin up but to no avail. PSU fan does not spin nor do I hear the hard drive spinning or feel it vibrating.
