My friend just plugged in his speakers, and they were just making a static notice. We made sure everything was plugged in. Any ideas?? The speakers are just some cheap $25 USD Logitech ones. We also updated audio drivers. Any help is welcome!!
“Appear weak when you are strong, and strong when you are weak.” - Sun Tzu, The Art of War #muricaparrotgang
Tier Lists and Specs List Below
Motherboard VRM tier list  -----  PSU tier list
React if you agree with me!
CPU: Ryzen 5 3600  |  CPU Cooler: Asus ROG STRIX LC240 White |  RAM: Crucial Ballistix RGB 16GB 3600 | Mobo: ASUS ROG STRIX B550-A  |  SSD: Inland m.2 NVMe SSD 256GB  |  HDD: Seagate 2TB 7200RPM |  GPU: RTX 3060 Ti FE  |  PSU: Seasonic SGX 650 |  Case: Lian Li o11 mini-W  |  Mouse: Razer Basilisk mercury |  Keyboard: Drop CTRL (Used. I did not spend $200 on a keyboard) |  Mouse Pad: Aura Mech Purple Storm  |  MonitorAsus TUF 24" IPS 144Hz 1080p
https://linustechtips.com/topic/1284005-speakers-making-static-noise-help/
Z200s? They're not half bad speakers for the avg consumer.
please quote me or tag me @wall03 so i can see your response
motherboard buying guide      psu buying guide      pc building guide     privacy guide
ltt meme thread
folding at home stats
pc:
RAM: 16GB DDR4-3200 CL-16
CPU: AMD Ryzen 5 3600 @ 3.6GHz
SSD: 256GB SP
GPU: Radeon RX 570 8GB OC
OS: Windows 10
Status: Main PC
Cinebench R23 score: 9097 (multi) 1236 (single)
don't some things look better when they are lowercase?
-wall03
hello dark mode users
goodbye light mode users
what are they plugged into?
can you try them plugged into a phone and do they go to static as well?
if it's a computer are they in the back or front connector?
are they in the line out or headphone out?
is the volume maxed?
The best gaming PC is the PC you like to game on, how you like to game on it
No, I believe they are Z130s.
Computer
Does not go static if plugged into iPad
They are in the front
They are at max volume
UPDATE:
Thank you both so much for your help!!
In the end, the audio header was just loose. Everything works now!
@GhostRoadieBL
@wall03
Again, thank you both so much!
