Budget (including currency): 1200e .But the less the better
Country: Austria
Games, programs or workloads that it will be used for: Programming(not demanding),Medival dynasty,battlefield 1,league of legends
I have 1080p monitor,will upgrade in the future to ultrawide or dual 1440p.
Gaming requirement is high settings,constant 60fps,more is not needed.I can buy today or tomorrow,i would like to be silent,no rgb needed,looks doesnt matter.
https://linustechtips.com/topic/1283886-first-build-help/
Country: Austria
There isn't any GPUS in stock, so don't buy right now.
geometry is hard
b550 > x570
https://linustechtips.com/topic/1283886-first-build-help/#findComment-14321106
Just now, Downkey said:
uhm rtx 3080 new one is between 700-850 euros in europe btw.
And can i go with rtx 2060 or amd 5600xt cause they are like 380-450 euros and i will never use 3080 potential since my game are not so demanding
https://linustechtips.com/topic/1283886-first-build-help/#findComment-14321111
1 minute ago, Tan3l6 said:
Erm, is the 600€ RTX 3080 real?
I think it's rather RTX 3060 Ti price.
I am in the United States, and 600€ translates to around $730 USD. And that's MSRP. So it sounds right, but there may be some reason why prices might be higher in Europe.
“Appear weak when you are strong, and strong when you are weak.” - Sun Tzu, The Art of War #muricaparrotgang
Tier Lists and Specs List Below
Motherboard VRM tier list  -----  PSU tier list
React if you agree with me!
CPU: Ryzen 5 3600  |  CPU Cooler: Asus ROG STRIX LC240 White |  RAM: Crucial Ballistix RGB 16GB 3600 | Mobo: ASUS ROG STRIX B550-A  |  SSD: Inland m.2 NVMe SSD 256GB  |  HDD: Seagate 2TB 7200RPM |  GPU: RTX 3060 Ti FE  |  PSU: Seasonic SGX 650 |  Case: Lian Li o11 mini-W  |  Mouse: Razer Basilisk mercury |  Keyboard: Drop CTRL (Used. I did not spend $200 on a keyboard) |  Mouse Pad: Aura Mech Purple Storm  |  MonitorAsus TUF 24" IPS 144Hz 1080p
https://linustechtips.com/topic/1283886-first-build-help/#findComment-14321118
Yup, where I reside there are no ways to buy a RTX 3080 below 1000€ when in the rare case it comes available in shops. RTX 3070 is around 700€ and 3060Ti about 530€.
Pax vobiscum
https://linustechtips.com/topic/1283886-first-build-help/#findComment-14321125
I would still recommend waiting. If you don't your build won't be as good for "as long" and you would want to upgrade earlier on.
if you wait you could get a 5600x and 3060ti/3070...
Also I set the wrong price for the 3080.
geometry is hard
b550 > x570
https://linustechtips.com/topic/1283886-first-build-help/#findComment-14321126
it doesnt go like that.Ps5 is 500usd which is 420 euros,but still we pay 500 euros for it.Everything is much more expensive then in US,often i would be looking at laptops and the price is much different then here in EU.
THis pc should last me at least 4 years before new upgrade.And i am not that much into gaming(3-4 hours per week),but even this small amount of time i would like to play it ok.
Currently BF1 on lowest everything possible gives me around 30 fps and i am still play it so you get that picture of my actuall needs
https://linustechtips.com/topic/1283886-first-build-help/#findComment-14321163
