My mums asked me to fix her old laptop, it’s a Sony vaio model pcg 7131M, but I’m not too sure what’s actually wrong, the screen has weird lines on it but only on the vaio screen not on the boot screen part. and it says I need to either start windows normally or repair , when I click repair it tried to repair the disk but it must of failed because I went away and come back it turned off I turned it back on to get the same screen. My question is should I replace the hard drive or motherboard? Neither is going to be expensive jus want to know where to start.
https://linustechtips.com/topic/1283550-troubleshooting-help/
Before you replace anything check if the hard drive is clicking. About the weird lines on the screen, it may be that the screen is slightly damaged or that the graphics card (if it has another one apart from the igpu) is damaged.
A guy asking and answering in his bedroom since he has nothing else to do
https://linustechtips.com/topic/1283550-troubleshooting-help/#findComment-14318920
What do you mean by clicking ?
https://linustechtips.com/topic/1283550-troubleshooting-help/#findComment-14327405
Sorry late, but if you listen to a hdd closley and hear slight clicking, it may be time to retire the drive
https://linustechtips.com/topic/1283550-troubleshooting-help/#findComment-14335402
