Post with no peripherals, none with.
Solved by BiL,
43 minutes ago, Cuwee said:Yes, hence why I am so confused
Do NOT plug you HDD just try to boot from a Live USB Linux disk (Linux Mint Cinnamon will do the job) which you can create on a spare PC or a Laptop and check the rest of the components from Linux environment.
Anyway you can buy a new SATA SSD and try installing Windows over it. Your old HDD is probably dead and causing a short circuit to your new PSU.
