Spent ten hours yesterday building my first rig, powered it up got to the post screen? It then told me to press delete to get to BIOS but it never would. The Orange Dimms light on the motherboard is lit. So I got different ram to try out, tried dual and single channel still nothing. I’ve got 5800 with Tuf 570 plus Wi-Fi, and was wondering if maybe it needs bios update to work?
Build list
5800x
Tuf 570x Plus Wi-Fi
Two different kinds of ram both DDR4 not near rig to see names at the moment
Western Digital 1TB M.2
 I know it’s fixable but just feel hopeless and don’t know what to do.
https://linustechtips.com/topic/1283161-first-build-whoas/
Welcome to the forums!!!
Yes, try updating your BIOS to the latest BIOS that supports AMD Ryzen 5000 series CPUs.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
https://linustechtips.com/topic/1283161-first-build-whoas/#findComment-14316364
Okay I’ve got a new flash drive 32G I just download newest patch on it and then what? If I can’t get to bios how do I tell the motherboard to take the update?
https://linustechtips.com/topic/1283161-first-build-whoas/#findComment-14316369
You can get a CPU loaner kit from AMD to update the BIOS using said CPU that is supported to install the newer BIOS and then swap CPUs to get up and running. If you bought your motherboard at a retailer such as Micro Center (don't know where you live), they can update the BIOS for you for either free or a small fee. Your motherboard does not have any sort of BIOS flash button on the back I/O or the PCB itself.
https://linustechtips.com/topic/1283161-first-build-whoas/#findComment-14316381
