Doom Eternal doesn't launch PLZ HELP
Go to solution Solved by -rascal-,
5 minutes ago, laiho420 said:
Specs:
CPU- AMD Ryzen 5 3600x
Motherboard- ASRock X570 Phantom Gaming 4
Ram- Corsair Vengeance (2) 8gb sticks DDR4 3200MHz
GPU- EVGA RTX 2070 Black Edition
Hi Guys NEED HELP Doom Eternal has been a problem the past month. I have done EVERYTHING I could find to make this game actually run on steam. Its HAS worked before. When you press the Play Button after a fresh Reinstall the id Launcher flashes at the bottom and goes away and that's it. I have done all I could find to fix this don't know what to do. I have uninstalled and reinstalled multiple times, running it as administrator, turning off steam overlay and I have updated Nvidia drivers. If anybody could help I would Greatly appreciate it.
Have you tried using the 'Verify Integrate of Game Files' function in Steam?
https://support.steampowered.com/kb_article.php?ref=2037-QEUH-3335
Is this a fresh Windows 10 install?
What version of Windows 10 are you running right now?
You should either be on Version 2004 (May 2020 update) or 20H2 (October 2020).
Specs:
https://linustechtips.com/topic/1282948-doom-eternal-doesnt-launch-plz-help/
Specs:
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
