Front usb C Meshify 2 case
Go to solution Solved by Diogo_01,
Hi can someone tell me if there is any pcie cards that have a front usb c connector i tried to search it but cant find anything.
im going to be changing my hardware to the meshify 2 xl case but my motherboard dosent have a front usb c plug and it kind of bugs me to not have it pluged in
https://linustechtips.com/topic/1282883-front-usb-c-meshify-2-case/
Note that you will have to connect it to the PSU.
https://www.amazon.com/PCI-USB-Type-Expansion-Card/dp/B077VRWZPK
“Appear weak when you are strong, and strong when you are weak.” - Sun Tzu, The Art of War #muricaparrotgang
Tier Lists and Specs List Below
Motherboard VRM tier list  -----  PSU tier list
React if you agree with me!
CPU: Ryzen 5 3600  |  CPU Cooler: Asus ROG STRIX LC240 White |  RAM: Crucial Ballistix RGB 16GB 3600 | Mobo: ASUS ROG STRIX B550-A  |  SSD: Inland m.2 NVMe SSD 256GB  |  HDD: Seagate 2TB 7200RPM |  GPU: RTX 3060 Ti FE  |  PSU: Seasonic SGX 650 |  Case: Lian Li o11 mini-W  |  Mouse: Razer Basilisk mercury |  Keyboard: Drop CTRL (Used. I did not spend $200 on a keyboard) |  Mouse Pad: Aura Mech Purple Storm  |  MonitorAsus TUF 24" IPS 144Hz 1080p
  • 3 weeks later...
