hello guys i try to instal win 10 on nvme kingston a2000. Motherboard find the nvme but when i go to instalation of windwos from usb flash its says there are no installed disk and its like i dont have any ssd or hard disk so i cant install it ? How to fix that i update bios but again the same motherboard is z370 gaming pro carbon AC. im so sad..
https://linustechtips.com/topic/1282436-nvme-m2-problem-please-help/
1 minute ago, True said:
humm   99% sure that chipset supports NVME..  are you uusinga M.2 slot on board or in a PCI adaptor?    have you verified the drive works in another pc to rule out a dud?
Its in m.2 slot i read that i should disable csm mode but im not sure it will work that
Just now, kali011 said:
i do this still not work oh boy.. i dont know what to do anymore...
Have you tried loading up command line from the windows installer and using diskpart to see if the disk is visible there?
try the following:
Click Install Now
Accept License Agreement
When the option is displayed to select an installation type, click (Custom Advanced)
Press Shift + F10 on your keyboard
type the following commands
"DISKPART" (Hit Enter)
"list volume" (Hit Enter)
this should show your m.2 drive in the volumes list. If it doesn't, try "list partition" and "list disk" to see if it shows up there.
3 minutes ago, True said:
I would suggest you try drive in another system to rule out dud.
Hard to convince me it's a dud if it shows up in BIOS... I've seen weirder things though so I won't count it out just yet.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
