Third Monitor stopped working
Solved by tract9on,
Unfortunately not. I've just tried using a DVI to hdmi to the TV and it still doesn't seem to be able to detect it. The same cable worked fine on my normal monitor ;l.
The TV does detect the fact it's been plugged into a HDMI source but isn't getting a signal.
Edit: Is there any way of forcing the graphics card to put signal through on a certain resolution?
Edit 2: I just checked by connecting my tablet via HDMI - the TV works fine and the tablet detected the TV.
Resolution: I powered down the PC, disconnected the graphics card and left it overnight. When I plugged it back in, it worked and detected the third monitor.
