UPS Fan swap
Go to solution Solved by viktorfilim,
1 hour ago, HairlessMonkeyBoy said:
This will probably work. Do you know how the existing fan connects to the system? standard 3 or 4 pin?
I don't know. I haven't opened yet the UPS. I want to gather more info first.
I suppose it uses the standard 3 pin because the fan is working at full speed regardless of load.
I wonder if the NF-R8 redux-1200 will move enough air so the batteries will not overheat. I do not use the UPS 24/7, I use it 3-4 hours a day during.
Hi,
Recently I've bought a rack mountable UPS. (LARICE | MP S RT2 1.5KVA - sorry, I can't find any links in English).
The problem is that it is very very loud. I'm using it in mobile audio rack and I need it to be as silent as possible so the performance of the singer is not disturbed.
The model of the fan that is currently used is HK FAN AB8025V12.
What fan should I get to replace this one? I know that I'll loose the warranty but sacrifices have to be made.
If the fan can not be swapped do you know any sound insulation I can use?
Thank you!
https://linustechtips.com/topic/1282319-ups-fan-swap/
https://pcpartpicker.com/product/ZwMFf7/noctua-case-fan-nfr8redux1200
Or you can get a low noise adaptor or put a potentiometer inline with the existing fan to reduce it's RPM.
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
https://linustechtips.com/topic/1282319-ups-fan-swap/#findComment-14310357
https://linustechtips.com/topic/1282319-ups-fan-swap/#findComment-14310656
There is a faster version:
https://pcpartpicker.com/product/TnkD4D/noctua-case-fan-nfr8redux1800
Also this:
https://pcpartpicker.com/product/XK8H99/noctua-case-fan-nfa8pwm
BigBox (HTPC):
  • Display: None
  • 2.5Gb NIC
NAS:
  • Synology DS216J
https://linustechtips.com/topic/1282319-ups-fan-swap/#findComment-14310681
  • 4 months later...
I'm in the same boat here, @viktorfilim. Have you solved it?
I don't see a reason UPS come with such a louder fan than to force us to mess with the warranty. Jesus.
I have opened my UPS to check it out and this fan uses a 2-pin pattern.
In order not to cut cables and do some nonsense, I decided to buy a 3 to 2-pin adapter.
After some research I decided to buy the FLX version of Noctua: https://noctua.at/en/nf-a8-flx. It already comes with some cables to further reduce the noise.
Unfortunately it will take a little while for the fan to arrive, because here in my country only one store currently imports Noctua, and as these small sizes are less in demand, they take longer to import.
I'll keep in touch
https://linustechtips.com/topic/1282319-ups-fan-swap/#findComment-14738929
So, just a heads up here, most UPS's use 12v batteries in series for an output of 24v, and thus typically have 24v fans.  Most computer fans like what you guys want to swap in are 12v.  You'll need step that down to 12v if that's the case.
Desktop: Ryzen 9 3950X, Asus TUF Gaming X570-Plus, 64GB DDR4, MSI RTX 3080 Gaming X Trio, Creative Sound Blaster AE-7
Gaming PC #2: Ryzen 7 5800X3D, Asus TUF Gaming B550M-Plus, 32GB DDR4, Gigabyte Windforce GTX 1080
Gaming PC #3: Intel i7 4790, Asus B85M-G, 16B DDR3, XFX Radeon R9 390X 8GB
WFH PC: Intel i7 4790, Asus B85M-F, 16GB DDR3, Gigabyte Radeon RX 6400 4GB
UnRAID #1: AMD Ryzen 9 3900X, Asus TUF Gaming B450M-Plus, 64GB DDR4, Radeon HD 5450
UnRAID #2: Intel E5-2603v2, Asus P9X79 LE, 24GB DDR3, Radeon HD 5450
MiniPC: BeeLink SER6 6600H w/ Ryzen 5 6600H, 16GB DDR5
Windows XP Retro PC: Intel i3 3250, Asus P8B75-M LX, 8GB DDR3, Sapphire Radeon HD 6850, Creative Sound Blaster Audigy
Windows 9X Retro PC: Intel E5800, ASRock 775i65G r2.0, 1GB DDR1, AGP Sapphire Radeon X800 Pro, Creative Sound Blaster Live!
Steam Deck w/ 2TB SSD Upgrade
https://linustechtips.com/topic/1282319-ups-fan-swap/#findComment-14738936
Thanks for the tip, but the little that can be found on Google about this model indicates that it is a 12v fan:
DC 12V 0.50A, 80x80x25mm AB8025V12 HK FAN AB8025V12 Server - Square Fan. PcHub.com - Laptop parts , Laptop spares , Server parts & Automation
https://linustechtips.com/topic/1282319-ups-fan-swap/#findComment-14738970
