Mobile CPU Turbo Boost
Go to solution Solved by Applefreak,
3 minutes ago, Prabhashbhajani said:
I have legion 5i with intel Core i5-10300h @2.5GHz which should turbo boost to 4.5Ghz.
When I run a game or any cpu intensive program the cpu clocks to only 4.19Ghz. Is it normal to boost to a clock lower than turbo boost at full load.
How can I take advantage of full turbo boost if it is possible?
Only 4.19, you're funny. No, but seriuosly you won't see all cores boost to the max. That's how the cpu was designed to avoid damaging it. On some laptops you can force it to but that could cause the device to either clock even lower or fail eventually. Just leave it as is and be happy you even get 4.19 on all cores. Other laptops will go below 3 ghz on all core workloads.
https://linustechtips.com/topic/1281949-mobile-cpu-turbo-boost/
Your CPU has a single core turbo boost to 4.5ghz. Dual core turbo boost is as you found out is set to 4.2ghz. I am not sure how you could set single core turbo boost to apply on all cores.
https://linustechtips.com/topic/1281949-mobile-cpu-turbo-boost/#findComment-14307796
https://linustechtips.com/topic/1281949-mobile-cpu-turbo-boost/#findComment-14307798
