I have a Turtle beach p11 and it picks up alot of noises from my computer that I don't want it to such as scrolling on mouse/dragging things. I have looked it up and apparently if I get a decent sound card it will fix this issue, so what sound card should I get. I would prefer one below £80
https://linustechtips.com/topic/128109-recommended-sound-card/
nb4 audio snobs cause flame war
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/128109-recommended-sound-card/#findComment-1703686
inb4 DAC
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
https://linustechtips.com/topic/128109-recommended-sound-card/#findComment-1703696
Wait, do you mean the microphone picks up sounds like the mouse's scroll wheel scrolling? If you mean that your microphone is picking up background noise like that, then a sound card really won't help. The problem would be an overly sensitive microphone.
If you mean that there is hiss or other abnormal noises coming out of the speakers of the headphones, then an internal sound card might not help since just like an on-board chip, it resides inside the case with all the interference. Thus, an external sound card/dac would be better solution.
https://linustechtips.com/topic/128109-recommended-sound-card/#findComment-1703727
