What is a good less than $10 USB 3.0 Flash Drive? On Amazon with prime shipping? http://www.amazon.com/s/ref=nb_sb_ss_i_0_16?url=search-alias%3Daps&field-keywords=8gb+flash+drive+usb+3.0&sprefix=8gb+flash+drive+%2Caps%2C159&rh=i%3Aaps%2Ck%3A8gb+flash+drive+usb+3.0 There are so much but I don't know which is the best and reliable.
https://linustechtips.com/topic/128087-flash-drive-usb-30/
Under 10 bucks?
You're not going to really see a difference drive-to-drive.
Just pick one that's pretty.
Case: Lian Li PC011-D - CPU: 3900x - GPU: 2080ti Reference - Mobo: Gigabyte - Ram: Corsair 4x16gb 3200MHz - SSD: 2TB Samsung Evo NVME
https://linustechtips.com/topic/128087-flash-drive-usb-30/#findComment-1703449
If the USB 2.0 version is cheaper then get that.
There will be no difference in speed.
    CPU: 3930k  @ stock                                  RAM: 32GB RipjawsZ @ 2133Mhz       Cooling: Custom Loop
MOBO: AsRock x79 Extreme9                      SSD: 240GB Vertex 3 (OS)                     Case: HAF XB                     LG 34um95 + Ergotron MX Arm Mount - Dual Review
  GPUs: Gigabyte GTX 670 SLI                     HDD: 1TB WD Black                                PSU: Corsair AX 860                               Beyerdynamic - Custom One Pro Review
https://linustechtips.com/topic/128087-flash-drive-usb-30/#findComment-1703466
