Im looking for build a AMD rig and i'm looking for a Water Cooling Kit not a AIO but a real kit
11 hours ago, Fatty522 said:SO i went shopping on https://www.ekwb.com/ and i love it! is there anything to stay away from? like junk you don't reality need? or everything on that site are g8 and cant go wrong..
I dont really think you can go too far wrong, like I said before I thi k it's best to avoid their "fluid gaming" range but I dont think they sell it anymore, at least in individual component form.
I went for all quantum range stuff, basically you need as a minimum a reservoir and pump (or a res/pump combo), a cpu block, gpu block and radiator. Then decide if you want hardline or soft tubing and get a load of fittings to suit. Also dont forget a valve and fitting/tube to make a drain from the lowest point.
My lessons learned are:
1. loads of people make a massive fuss about leaks and hard tubing being difficult etc. My opinion is it depends how practical you are, I've worked on cars and other mechanical things for years so found a hardline loop really not that difficult. Soft tubing would be a lot easier though, I just dont like the way it looks.
2. Buy extra fittings, I only bought regular "straight" fittings and could have done with a few more 90deg adaptors etc.
3. Make sure you have enough coolant - I'd say 1litre is likely enough for most cpu/gpu loops.
4. I'd recommend adding a coolant temp sensor too (assuming your mobo can take an external sensor).
5. Pick PETG or acrylic, I ended up using a mixture of the two and I cant tell the difference other than petg heated up a lot quicker. If going soft tubing this isnt applicable.
6. I used solid cryofuel coolant. Again everyone will bang on about how it's bad, it has sediment, it discolours. I'm a few months in using solid white and it still looks brand new.
7. Distilled water is a load of nonsense. You can rinse with tap water if you really need to, but I admit I went and got deionised water for a couple of quid just to be on the safe side.
If going hardline you will need a heat gun, set square or something similar to measure right angles etc. and for the sake of a couple of quid I got the psu bridge so you can fill it up without any power to your actual system. If it does leak, it wont matter.
I'll add a link to my build thread and you can see what I managed with my first attempt.
HTH buddy!
