Budget (including currency): 1.8k$
Country: USA
Games, programs or workloads that it will be used for: Streaming, Video Editing, Gaming (like Cold War for example) and maybe VR in the future
Some parts are already bought like the case and peripherals.
I just want to confirm the Ram (3600 or bust) and Motherboard first
This will be my new daily driver and gaming machine so also want to futureproof some parts as to not upgrade for some time
Also what's some alternatives for my gpu because 3070 doesn't exist
https://linustechtips.com/topic/1279395-new-build-help/
You'll want to get a 5600x rather than a 3700x. Get a better power supply. The rest is fine.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/1279395-new-build-help/#findComment-14288945
2 minutes ago, Kai Alter said:
Ok so I added the Ryzen 5 5600x from pcpartpicker and it's telling me the MB will need a bios update before it can use the CPU
It should be okay. And get a better power supply. Something in Tier A is completely in your budget.
https://linustechtips.com/topic/1279395-new-build-help/#findComment-14288961
Cpu: 5800x is top of the line gaming cpu.
Motherboard: B550- A Pro can handle 5950x overclocked well. Decent motherboard overall. Overkill for the 5600x.
Ram: With Ryzen over 3000mhz memory is recommended. Upgraded to 3600mhz cl 16 form 3200mhz cl 16. There is not that much of a difference.
Storage: The rocket 4.0 is very good and has decent value. Should be used to store system and main games. The MP34 Ssd is great and should be used to store games.
Gpu: Rtx 3080. Good encoder for streaming and recording + somewhat decent Rtx performance and DLSS.
Case: The case has very good airflow. Paired with 6 decent fans. 1x rear exhaust, 2x top exhaust and 3x front intake.
Psu: Currently overpay but is at stock atleast. should be around 100$ for this psu. Anyway this psu is very good and can handle 3060ti and 3070 just fine.
Cooler: Also very quiet cooler cabable of cooling even 5900x easily.
Notes: Fans come with fan controller. The psu is semimodular. Cables can get tight with the P400A. The case does not support radiators on the rear or on the top. Do not get an AIO for this case. For the gpu use 2x pcie cables from the psu. Not 1x cable with daisy chained 2x8pin. Rocket 4.0 is pretty overkill, but great Ssd. 750w psu might be tight with 3080. But 5800x does not use much power. IT should be fine. You can get 850w psu is you are not comfortable.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1279395-new-build-help/#findComment-14288999
