43 minutes ago, Mling said:
I have just been given an Intel nuc and I think I'll turn it into a wifi router. What is a good OS to use? One with a web interface.
Have a look at this article:
https://www.geckoandfly.com/24015/router-os-enterprise-network-switch/
I've used PfSense in the past, which is great and lightweight. Also provides full UTM firewall.
https://linustechtips.com/topic/1279368-wifi-router-os/#findComment-14288853
I have also used pfsense. I had an issue with using it with wireless. It would forget the settings for the wifi on reboot. That would not be a problem except I will only be using this for wifi. I have no ethernet cables in my house.
https://linustechtips.com/topic/1279368-wifi-router-os/#findComment-14291369
