I recently bought my pc but the cpu is heating up really fast because it doesn't have fans in the front(I talked with the guy where I bought it but he said it'll work fine and I trusted him), I was wondering what kind of fan on the front panel could cool everything inside the case(i plan on buying only 2 fans).
The specs of my pc are: Kolnik Inspire K7 ARGB, Asus Prime B450M-A, Ryzen 5 3600 (with stock cooler), GTX 1660 Super Ventus XS OC, G.Skill 2x8gb 3200Mhz, 240gb kingston A400 SSD, Kolnik Inspire 700w 80plus gold.
My options for the front panel fans are:
SilentiumPC Sigma HP Corona RGB 120mm and Yate Loon D12BM-12.
image.png.a154c3932bda16fe9d0a98e6aeafcc77.png                                           image.png.a9b45c58585606d9fa6a965de6928819.png
https://linustechtips.com/topic/1279007-need-some-help-with-my-pc/
Either fan will be fine, they both blow air after all.
Buy whichever you want.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
1 minute ago, boggy77 said:
what temps are you seeing under load?
Well when the cpu is on idle with the side panel off 42-68C, with panel on 50-70C.
While gaming with panel off 60-90C and it spiked 95C, haven't tested it with the side panel on.
sounds like a badly mounted cooler, rather than lack of airflow. try to remount and also update bios and chipset drivers
* thread moved to the Troubleshooting section *
Either the CPU coller has an issue, or it's an extremely restricted case, but seeing the idle temps with the side panel off, I'm guessing it's a CPU coller issue.
If you need help with your forum account, please use the Forum Support form !
I tried to cool it with cardboard by moving it around the case(just to see if the CPU temperature got lower) and the temps got cooler, so I think the issue is that the CPU stock cooler isn't getting enough fresh/cold air.
