If your computer is not posting there is a number of factors that may be holding it back - a post is a (Power On Self Test)
  • The BIOS verifies RAM.
  • It checks for a keyboard and mouse.
  • It looks for a PCI bus and then checks the cards that are installed.
  • The system information is then displayed on the screen.
You can work your way through the parts or try from the list below.
-------------------------------------------------------------------------------Hopefully this will become a sticky! :-)
CPU
Make sure the 4-pin motherboard connecter is plugged in
Make sure the CPU heatsink fan is plugged in
Resetting CMOS
Many No POST failures are caused by your computer's CMOS settings being corrupt
Resetting the CMOS to defaults will cure this, and possibly allow your computer to POST
By reading your computer's or motherboard's Manual (discussed further down this page)
Locate the CMOS battery and/or the "reset CMOS jumper" on your motherboard
Following the reset CMOS procedure (usually shorting two pins, with CMOS battery out)
Your CMOS settings will be reset, hopefully allowing your computer to startup (or POST)
RAM
Try booting with only one stick of RAM, still dont work? try the other
Connections
You can remove all drive data cables
Unplug case fans from the PSU
Display
Re-seat the GPU
Try a new HDMI/DVI cable you know is definately working
Remove GPU altogether and boot using motherboards onboard VGA
Dust
Dust can conduct electricity. Dust and debris, is usually the biggest factor on computers that will not start. Using High compressed air, or a vacuum cleaner, remove all dust from the computer. With special attention on all Fans; the CPU; the Ram; and the Power Supply Unit
PSU
Just because some lights come on, does not mean your Power Supply is working properly.
Ensure the PSU works by testing in another unit.
https://linustechtips.com/topic/1279-complete-no-post-guide/
Something to add: Populate the DIMM slots in the correct order with your RAM.
This once caused my computer to not POST.
Check your motherboards manual for DIMM slot order, or see if the motherboard has the DIMM slot number on it already.
Feel free to ask me for any advice, and I may ask for yours too. I'm an otaku. =)
Steam: hiddenshadow8
Skype: phantom8258
https://linustechtips.com/topic/1279-complete-no-post-guide/#findComment-17313
your feedback is appreciated - I dont know how to edit my original post - or else I would :') and add your info! Thanks though.
https://linustechtips.com/topic/1279-complete-no-post-guide/#findComment-17319
Also check your IC's on the motherboard. Especially if there are removable ones. My motherboard was shipped with the two legs of the IC jumping into one socket. Best tools are Patience, process of elimination, observation and This forum! :-D
i5 3570K (4.5Ghz OC)|4x4GB 1600Mhz Corsair Vengeance pro|Zotac GTX 980 Amp! Extreme Edition|Asus p8Z77M-pro|Raidmax 500 80+Br| 128GB Kingston Now SSD|2x1TB Western Digital Blue| Artic White Define R4|Corsair H60 cooler|CM Storm Quickfire MX BLUE| White Corsair M65
https://linustechtips.com/topic/1279-complete-no-post-guide/#findComment-19261
Firstly copy your whole post, then click edit at the bottom of the post. Now paste in the copy and edit what you need, click save. Done :)
Skype: phantom8258
https://linustechtips.com/topic/1279-complete-no-post-guide/#findComment-19551
