Current Cpu fine or na?
24 minutes ago, Jimmeuh said:on this generation games
Like do mean triple A titles, indie, ect? Theres a LOT of games, and it depends on that specific game. Some games may be able to get you 100fps+ but if your thinking more like AC Valhalla, Cyberpunk, COD, ect. then your CPU will need an upgrade if you want more than 100+fps. Resolution is also as important 1080p a GPU can output more fps, than at 1440p than compared to 4k so closer to 1080p the more likely a CPU becomes a bottleneck, and the closer to 4k the more likely your GPU will become a bottleneck. You also only need that upgrade if the actual games your playing are not running to your satisfaction, and you can actually handle that higher fps. I highly suggest considering if you actually need an upgrade since prices are terrible right now and stock is garbage.
