yeah i put them at 1100 as i did the same for the stock fans
Put them on max, they aren't loud.
Also there's no temp difference between stock fans and noctuas. Noctua slightly looses by 1-2 degrees, at least that's how it was for me (H70).
Usually people replace stock to noctua not for performance, but for for silence.
https://linustechtips.com/topic/12787-ncotua-problem/#findComment-137068
are they turned around the right way? it could affect the temps if its pulling/pushing hot air through
cpu: 3570k cooler: H100i m/b: Asus Maximus V Formula ram: 16gb Corsair Vengeance gpu: Asus Nvidia GTX 680 DCUII ssd: Samsung 840 pro hdd: WD Black 2tb case: CMStorm Stryker psu:  Corsair AX860
https://linustechtips.com/topic/12787-ncotua-problem/#findComment-137467
Push or pull both wield the same temperatures
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
https://linustechtips.com/topic/12787-ncotua-problem/#findComment-137473
He was talking about taking air in from the top, you kind sir should plug the fans into some pwm headers on the mobo
Codename: HighFlyer, specs:  CPU: i5 2500k cooled by a H70ish(2 rad)   Mobo: MSI MPower Z77   GPUs: Gigabyte GTX 660 OC 1150 MHZ core, 3150 memory both   RAM: Corsair Vengeance 16G @1600mhz   SSD: ADATA Premier Pro sx900 / HDD Seagate Barracuda 1TB/Samsung 1TB   Power supply: Corsair RM650 80+ Gold   Case Corsair Carbide 500R   5.4 ghz achieved on the good old 2500k, may it rest in peace. Current daily OC is 4.8 @1.41 v
https://linustechtips.com/topic/12787-ncotua-problem/#findComment-138828
