intel i9-9900k temp help
Solved by Downkey,
5 minutes ago, NotAOverclocker said:ive recently installed a new i9-9900k in my system coupled with a noctua nh-d15 heatsink with both fans installed. When i game my chip reaches 80-83 degrees C when gaming sometimes spiking up to 90 for a quick second then settling back down to 79-83 degrees. When hitting it with a full load in intel XTU it hits the same around 79-83 degrees are these reasonable temps or could this potentially damage the chip.
specs: mobo- msi z390 mpg gaming motherboard
GPU- rtx 3090
cpu: i9-9900k
ram :32 gbs trident z 3200 mhz
Those are pretty high temps, but currently it's not really anything that will kill your CPU
