Im using my pc without an Io shield, it doesnt ground as well is it can but its not a massive problem, keep it off the carpet and dont "violently" rub it while you have cloth on.
Listen if you care.
https://linustechtips.com/topic/127831-io-shield-help/#findComment-1699709
Call the manufacturer for one.
https://linustechtips.com/topic/127831-io-shield-help/#findComment-1700702
