Hello guys,
I just recently build my first PC and I'm encountering problems with it. So the issue is sometimes when I open my PC it will reach login to windows then the screen will be blank (there's no display) the after a minute or two it will open again and once I enter my credentials then there's a notification popup describing 'Radeon Wattman setting has been restored due unexpected system failure'. There's no issue when I'm gaming or browsing just during startup.
I don't know if it has something to do with this but after I successfully installed windows I tried to install AMD Radeon driver then I updated my display driver. after that I cant open the AMD Radeon software then its says that the version of display driver is not compatible so I tried to revert it (display driver from device manager) and uninstall and reinstall the Radeon driver.
Hope this problem wont brick my pc :(
Here is my PC specs:
MSI B450 Tomahawk
Ryzen 5 3600
Sapphire RX 5700 XT Pulse BE
G.Skill Ripjaws 8x2 3200
250gb SSD
Corsair 550w cv550
https://linustechtips.com/topic/1277043-amd-wattman-settings-issue/
