Hey, i am upgrading my pc to a new one, going to be buying the ryzen 5 5600X, with 16 GB RAM, and i cannot decide on the graphics card. right now i have a gtx 1050 ti and have had it since 2016. At first i was going to upgrade from it to 1660 super, which is 8.36% bottlenecking with cpu, but since 3060ti came out i cant decide. Can i just use 1050ti with the new build, then buy the 3060ti when its price comes down, or should i just buy the 1660 super right now? I am going to be using my pc for basic blender, video games and basic video editing.
https://linustechtips.com/topic/1276940-need-pc-build-advice/
buy a 3060 ti later, you'll get a bit of better preformance because of the new cpu. Also where do you have that data with the bottle neck from
Any Help is appricated! Please correct me if I´m wrong!
Sorry for grammer/spelling mistakes, but english is not my native language
https://linustechtips.com/topic/1276940-need-pc-build-advice/#findComment-14271172
3 minutes ago, Pika_Chew said:
Dont rely on this kind of sites, no hardware is the same
https://linustechtips.com/topic/1276940-need-pc-build-advice/#findComment-14271179
you could run rtx 3080 just fine with 5600X, do not trust the bottleneck calculators. they are just as bad as wattage calculators and Userbenchmark.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1276940-need-pc-build-advice/#findComment-14271233
