Dual monitor lower fps??
Solved by Oshino Shinobu,
2 minutes ago, Kairu said:The only problem with that is my 2nd monitor doesnt have a DVI port, I'll try to get a VGA to DVI cable, on the other hand would that cable lead to any performance dips? Thanks for the reply btw.
If your GPU as DVI-I, get a DVI-I to VGA and it will work fine. If it only has DVI-D, you'll need an active converter to go from DVI-D to VGA.
Neither a DVI-I to VGA cable or DVI-D to VGA converter will lead to any performance dips.
