In the last couple of days I've had several BSOD with several different codes starting with: System_Service_Exception. I looked up the code and ran a memory diagnostic, updated windows, and ran the windows driver verifier tool through admin windows powershell. This worked for a day and then I got another BSOD with the code: Memory_Management. Ran a memory diagnostic and ccleaner and then got another later that said: Kernel_Security_Check_Fail and finally got one this morning saying: IRQL_Not_Less_Or_Equal. As per the BSOD posting instructions I have attached the dump files and resource and performance monitor results. Any help you could give would be greatly appreciated!
EDIT: While editing this post crashed again with the code: IRQL_GT_ZERO_AT_SYSTEM_SERVICE
System Specs:
Windows 10 64-bit
AMD Ryzen 7 2700X
16 GB DDR4 2133 MHz (2x8 GB sticks)
ASRock Fatal1ty B450 Gaming-ITX/
MSI GTX 1070
Corsair SF600 power supply
112920-10109-01.dmp 112920-10843-01.dmp 113020-13484-01.dmp 120120-13093-01.dmp 997461520_ResourceandPerformanceMonitor.html
https://linustechtips.com/topic/1275889-4-different-bsod-please-help/
