Budget (including currency): 2200 Dollars
Country: Sweden
Games, programs or workloads that it will be used for: Primarly Gaming, however some editing may occur.
No existing parts, no peripherals are needed. Upgrading from 1060 6GB and i5-4430. 144hz 1440p is what I am going to aim for.
OPTION: (5600x / 3080 instead maybe? I am not sure, it is easier in the future to upgrade GPU and therefore 5800x is more futureproof?!)
Live-bild
Any improvements to be made? Anything to think of when installing and putting the computer together?
Thanks for any help,
Best regards,
Gustaf
(One question I got is that does the motherboard support all the fans, I am unsure as I have not been able to find any information about this. If this is NOT the case, how do I deal with this matter?)
https://linustechtips.com/topic/1275840-premium-build-suggestions/
2 minutes ago, boggy77 said:
looks good. for mostly gaming, i'd go with 5600x+3080 over the 5800x+3070
That is what I am also thinking about. The thing is that it is a more advanced procedure to change the motherboard and or the processor in the future, where as the gpu is way easier.
1 minute ago, Guzze said:
That is what I am also thinking about. The thing is that is more advanced procedure to change the motherboard and or the processor in the future, where as the gpu is way easier.
if you're not buying now, and are willing to wait a bit, it's likely amd will release a 5700x at some point early next year
Same performance and a lot cheaper...
PCPartPicker Part List
CPU: AMD Ryzen 7 5800X 3.8 GHz 8-Core Processor (kr4990.00)
CPU Cooler: be quiet! Dark Rock Pro 4 50.5 CFM CPU Cooler (kr895.00 @ Computersalg)
Motherboard: MSI B550-A PRO ATX AM4 Motherboard (kr1347.00 @ Computersalg)
Memory: Corsair Vengeance RGB Pro 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory (kr1671.00 @ Proshop)
Storage: PNY XLR8 CS3030 1 TB M.2-2280 NVME Solid State Drive (kr1477.00 @ Proshop)
Video Card: Gigabyte GeForce RTX 3070 8 GB GAMING OC Video Card (kr7257.75 @ Dustin Home)
Case: Fractal Design Meshify C ATX Mid Tower Case (kr991.00 @ Proshop)
Power Supply: BitFenix Whisper M 650 W 80+ Gold Certified Fully Modular ATX Power Supply (kr999.00 @ CDON SE)
Total: kr19627.75
Generated by PCPartPicker 2020-12-01 15:54 CET+0100
You can go with something like this and even fit in a 3080.
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
