Budget (including currency):  3,000USD ($)
Country: United States of America
Games, programs or workloads that it will be used for:
This build will be used primarily for adobe suite products, more specifically Adobe After Effects. I'm looking for the best performance I can get. Adobe After Effects really benefits from single core performance, so I'd like to achieve the highest single core performance I can get for the price. I'm currently specing out a build on PC partpicker, but it's been a while since I've built me last PC. Any suggestions would be greatly appreciated! :)
Other details NA
Other details NA
Very overkill. If you want to reduce the price you can get a worse SSD, 32GB of RAM, and the HDD can be removed
geometry is hard
b550 > x570
21 minutes ago, Downkey said:
Just to add to this if op wants to around 400$ can quickly be saved without any performance impact at all.
