Pc build help
Solved by Downkey,
3 minutes ago, Rhb said:I’m doing a $600 pc build
I need help choosing parts
I need the following
motherboard-mini itx
cpu
ram
gpu
I’m using nzxt h1 for case
Case is $300
so $300 for the other parts
I already have rx 560 should I use it or get another card
Wait, your spending $300 on a case when you have $600 as your budget? Why?
