Need to connect my Case fans to my Motherboard, non adjustable speeds as connected wrong.
Solved by Rooked,
16 minutes ago, LouisHend said:The fans connected to the chassis and CPU are working fine and have speed adjustment, yet in the bios, as one is connected to the AIO, it isn't able to be adjusted and is locked at 100% power, this makes my system very loud.
Nevermind, I see what you mean. You can try getting a fan splitter for your fans, they should enable you to change your speed. Sorry, I got your fan headers mixed up. Thought you had an AIO pump.
