Hi everyone,
The other day i was streaming Rainbox Six Siege, and i was gettin 144 fps as usual (i have a 144hz monitor) but the stream was lagging, so i turn down the v-sync in game to 60 and the stream stop lagging.
There is any way to stream the game with 144hz enable?
I have a R5 3600, RTX 2060s, 16GB DDR4 set ot 3200mhz
I am using for streaming 1080 30fps, 4500 bit CBR, Perfomance setting for the NVENC Encoder
I have also another old monitor for the chat and stuffs (it is 1080p 60hz)
Thanks everyone and sorry for any errors i am from Italy 😅
https://linustechtips.com/topic/1275268-streamlabs-problems-with-high-fps-game/
Unfortunately there isn't, the issue is low bitrate and Twitch set a hard limit so its really out of your control. 1080p60 is plenty for streaming anyway.
Main Rig:-
Server:-
4 minutes ago, Rooked said:
That's your problem right there. Try getting 60fps on that and see how it looks.
Previously i was streaming in 1080p 60fps but in R6 Siege and F1 2020 if the v-sync was over 60 the stream starts lagging
What do you mean the v-sync over 60? I'm presuming it's your frames. Anyway, I found a thread that looks similar to yours. You can maybe have a look over it.
https://obsproject.com/forum/threads/obs-streaming-from-144hz-single-pc.100419/
I mean if i set V-sync to 120 or 144hz, thanks for the thread
