I am going to build a pc in the inwin a1 plus case, this case comes with 2 Argb fans and a rgb strip. I am going to be adding an additional argb fan to the back of the case. Will I need to buy an rgb splitter. I saw in the manual that the case fans and rgb strip connect together, could I do this with the three fans and strip even if the other fan is a different model?
https://linustechtips.com/topic/1275246-rgb-fan-help/
