Budget (including currency): $1000
Country: Canada
Games, programs or workloads that it will be used for:
hey guys im building a pc so i wanted to know if these parts are compatible
Motherboard: Asrock b450 steel legend
cpu: Amd ryzen 5 2600
gpu: rx5600xt gigabyte oc
ssd:550gb crucial
powersupply: 600w
case: corsair carbide spec o4
fans: uphere 120mm 3 pack rgb with remote controller
https://linustechtips.com/topic/1274708-rx5600xt-i-need-help/
Country: Canada
ssd:550gb crucial
powersupply: 600w
Well they are compatible but you may want to go from a 550GB SSD to an 1TB one.
https://linustechtips.com/topic/1274708-rx5600xt-i-need-help/#findComment-14254088
You're missing RAM, do you already have that?
CPU - Ryzen 5 5600X | CPU Cooler - EVGA CLC 240mm AIO  Motherboard - ASRock B550 Phantom Gaming 4 | RAM - 16GB (2x8GB) Patriot Viper Steel DDR4 3600MHz CL17 | GPU - MSI RTX 3070 Ventus 3X OC | PSU -  EVGA 600 BQ | Storage - PNY CS3030 1TB NVMe SSD | Case Cooler Master TD500 Mesh
https://linustechtips.com/topic/1274708-rx5600xt-i-need-help/#findComment-14254096
Just now, shailp567 said:
ye lol my bad but the asrock motherboard is good right? im jus worried bout that
The motherboard is fine, but I made a better build with a Ryzen 5 3600 and more storage:
https://linustechtips.com/topic/1274708-rx5600xt-i-need-help/#findComment-14254106
