G pro wireless, Viper ultimate or Model o wireless?
ZZennaH
Now on Black Friday all of these mice are at the same price where I live. Which one is the best? Should I wait a year or so do the G pro x superligt, to go on sale?
Depends on your grip style and hand size. If they are all the same price, I'd get either the Viper or the G Pro though. The Model O is good, but shape wise is almost identical to the Viper which has optical switches, the dock and no holes, so I'd just go with the Viper. The Superlight isn't worth paying 2x more than the G Pro Wireless tbh, I'd only consider it if you are really serious about gaming (or if you really want the lowest weight or the white color).
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
