Computer freezes when using USB stick
Go to solution Solved by PorkishPig,
Hi. I bought a ''Kingston DataTraveler 64gb'' from a dutch retailer about a year ago and stored some files on it, but after putting them on, I never used the thing in the meantime. It's about 50GB of data (which I don't need anymore) so I thought to myself lets go format the drive. When I'm in windows and I insert my USB stick and go to file explorer, if I try to open or rightclick the usb stick, it loads for an extremely long time (after 30 minutes still no result). If I click anywhere else on my pc, it crashes. If I try to turn the pc off, then insert the usb stick and try to boot into windows, it won't get past the loading screen of windows (the one right before you login). I've tested this with 2 desktops and 1 laptop, all have the same result. Any tips?
(P.S the specs of all 3 pc's are (rougly) i7-4790K, GTX 1660TI, 16GB ram)
Kind regards,
https://linustechtips.com/topic/1273432-computer-freezes-when-using-usb-stick/
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
or use rufus and format the drive, I've found this especially helpful on drives that have several partitions that were created. https://rufus.akeo.ie/
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
2 hours ago, StDragon said:
You can erase the drive with the DISKPART CLEAN command; assuming the drive isn't faulty.
https://www.buffalotech.com/knowledge-base/cleaning-a-disk-in-windows-7-using-diskpart
Yes, the link above works with Windows 10 too.
2 hours ago, PorkishPig said:
Thank you very much :)
