1 minute ago, Activalix said:
So we tried that, and now we can get to a boot-screen
it sounds like it's working then?
Primary PC:
PSU tier list
How many watts do I need?
4 minutes ago, Activalix said:
My friends PC is refusing to post now. After a recent upgrade from a Ryzen 3 2300X to a Ryzen 5 3600X as such we tried to update the BIOS as aforementioned as it's meant to be done. So we tried that, and now we can get to a boot-screen
I don't see a problem here. Continue and see if it can boot into Windows now.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
3 minutes ago, Activalix said:
yes apologies can't*
could you list the specs via a pcpartpicker.com list
and make sure you quote us so we can see your responses
Primary PC:
PSU tier list
he has a prebuilt C series cyberpowerpc et8880 if that's not specific enough he's got a a320m r4.0 board with a Ryzen 5 3600X. The PSU is fine with enough wattage.
did the 2300X work after the BIOS update?
Primary PC:
PSU tier list
20 minutes ago, Activalix said:
We haven't tested it yet. my other friend has it in his possession. So you'd recommend testing it with the previous CPU?
If the BIOS update failed, neither CPU would work, but if the 3600X was the problem, it would be the only non-working CPU
but phase1_initializer_fail is a bluescreen error, as far as I know, correct? does that mean you can get to windows?
Primary PC:
PSU tier list
