New PC build - need help!
Solved by boggy77,
9 hours ago, Kumar13 said:I heard you have to do some sort of BIOS update for the new AMD 5 series. I know this MOBO is compatible but do I need to take any extra steps to make sure its going to work? Also, I know this is a relatively budget cooler, but would it be enough to handle the workload of the games I'm looking to play?
Sorry for all these questions, just really unsure of some things. Appreciate you helping out!
The board supports bios flashback. In case the bios it ships with is not compatible with the cpu, you can update the bios on the board using a usb stick without the cpu installed.
The 5600x is such and efficient low power cpu that it doesn't need a bigger cooler.
