I'm debating whether I should get a new CPU for my esxi server (currently using 16 thread CPU and consuming approx 120W/hr), for something a bit lower power with an iGPU.... might even consider going intel for new mobo + cpu. At current prices it's costing about £144 a year to power it 24/7, so approx 2 years worth of power to buy something like a 10300 that has 4 cores 8 threads or even the 10400 for 6/12, which if I only power a few VMs up at any one time should be enough I think.
Anyone using a 10300/10400 for a 24/7 build can comment on power draw?
I considered a really low power build, but they have crap amount of cores. Unless there's some I don't know about that people could recommend?
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/1272170-esxi-build-power-draw/
Just now, mahyar said:
what do you use the server for?
there are some interesting options if you can go arm
Well that's why I'm using ESXi now rather than bare metal, so I can spin up VMs of different OS whenever I want. But ones I have running on there constantly ATM are my freenas VM that's doing all my storage needs with an LSI HBA passing the disks through to the VM, and an ubuntu 20.04 VM that I use for a few things, not least of which is if I realise I need to copy some data to/from freenas, I can remotely connect on any of my desktops/laptops to accomplish this without needing to keep the machine running after I've started the copy operation.
I have more planned to do, but haven't gotten around to it yet as I only set it up a few days ago.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/1272170-esxi-build-power-draw/#findComment-14235233
9900t is a good option
if it was useful give it a like :) btw if your into linux pay a visit here
https://linustechtips.com/topic/1272170-esxi-build-power-draw/#findComment-14235242
Thanks, I'll have a look at that and see if it's a viable option... not sure where to buy in the UK and/or if the cost is going to be extreme.
20 minutes ago, zhnu said:
Check out supermicro embedded epyc or embedded atom, for low power consumption.
Think they'll be out of my price range for this build... plus I think they are more for rack server builds IIRC, which I'm not looking for currently as don't have the space for a rack ATM. Sorry I should have been clearer about my current needs.
I currently just bought a silverstone https://uk.pcpartpicker.com/product/2FjG3C/silverstone-case-sstgd08b
And it's living on my media/entertainment center in my bedroom, so a rack is out of the question for sure as it'd be too loud. Even as it is the silverstone is just bearable for noise at night. I am goinjg to swap in some silent wings fans to see if that makes a difference.
Thank you both for the suggestions.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/1272170-esxi-build-power-draw/#findComment-14235434
btw there are a bunch of 10th gen T chips
10900t
10300t
10500t
and 10900t is about 270$ in aliexpress with free shipping and 9900t isnt available as it was
https://linustechtips.com/topic/1272170-esxi-build-power-draw/#findComment-14235448
10900t
10300t
10500t
Ahh cool, thanks again, will check out those.
20 hours ago, zhnu said:
Some interesting ones there, I love the look of the 16c atom, I saw that when they were released. I will have to see if my budget could stretch a bit for those. But they will stay on my wish list for sure.
Thank you both again. they are definitely interesting at those power draws.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/1272170-esxi-build-power-draw/#findComment-14237756
