Hey guys, just set up my custom loop about a week ago
Specs
XSPC - Tubing, ax 360 rad & raynstorm block
EK - 680 lightning block, fittings, pump d5, res, 240 xt & coolant
Fans - Noctua nf-12's & xspc
I have my CPU oc'd to 4.5ghz
I am runing prime 95, these temps seem high to me? all fans are running off noctua low noise adapters and y splitters.
post-54117-0-04938900-1394787862_thumb.p
https://linustechtips.com/topic/127186-high-temps-for-custom-loop/
66 - 71 - 74 - 71
What voltage are you running?
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
Specs
build specs works best.
CPU model and voltage. (if running p95 on haswell yeah, it'll be toastier because p95 uses more voltage than necessary creating more heat)
PUMP? speed?
Prime does have a tendency to add volts as airdeano stated above, btw on that 4.5 ghz overclcok what volts are you putting through it. Also in real world scenarios, gaming, rendering what temps do you get?
Core - EVGA Classified 3 | i7 980x | 12GB Corsair Dominator GT | Lian Li P80 | Corsair 128 Neutron GTX | 2 x WD 500gb Velociraptor | Asus Xonar Xense | 2 x EVGA 590 | Enermax Platimax 1500
Water Cooling - Alphacool NexXxos 360 Monsta | TFC 360 | Alphacool D5 Vario | Alphacool 250 Tube res | EK Supreme HF Nickle Plexi | 2 x EK Nickle Plexi 590 WB | Aquaero 5 XT
FYI - running a stress test to get temp readings isn't really valid IMHO. Those types of programs are meant to push your system to the edge, and therefore, yes, high temps, etc. Primarily I will use something like that to test if an overclock is stable.
Better test - run your favorite game for 30 mins and see what your temps are. That is much more real world and what really matters.
FYI - those temps to me are fine on Prime 95 - folding on my rig keeps the water itself at a toast 62C :)
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
