I need opinions on this build. It will be used as a media center, gaming and recording pc, livestreaming pc, music production and casual use as well.
CPU: Intel Core i7-4770K 3.5GHz Quad-Core Processor ($269.99 @ Microcenter)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler ($97.16 @ Amazon)
Thermal Compound: Arctic Silver 5 High-Density Polysynthetic Silver 3.5g Thermal Paste ($6.73 @ OutletPC)
Motherboard: Gigabyte G1.SNIPER 5 EATX LGA1150 Motherboard ($386.99 @ Amazon)
Memory: Corsair Vengeance 16GB (4x4) DDR3 1600 1.35V (White) ($185.98 @ Newegg)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Disk ($139.99 @ Amazon)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive ($100.00 @ NCIX US)
Video Card: Asus GeForce GTX Titan Black 6GB Video Card ($1039.99 @ B&H)
Case: Cooler Master HAF Stacker 935 ATX Full Tower Case ($156.99 @ Mwave)
Power Supply: Corsair 860W 80+ Platinum Certified Fully-Modular ATX Power Supply ($179.99 @ Amazon)
Optical Drive: LG WH14NS40 Blu-Ray/DVD/CD Writer ($57.80 @ Newegg)
Operating System: Microsoft Windows 8 (OEM) (64-bit) ($97.98 @ OutletPC)
Keyboard: Logitech Wireless Combo MK260 Wireless Standard Keyboard w/Optical Mouse ($35.40 @ SuperBiiz)
Total: $2,754.99
Any help would be most appreciated :)
https://linustechtips.com/topic/127107-need-help-on-a-build/
Total: $2569.01
Posting the pcpartpicker permalink makes it easier to review a build and available options.
Why a Titan Black?
Do  you plan to buy memory?
Why such a large psu?
Why did you choose the G1.Sniper 5 motherboard?
https://linustechtips.com/topic/127107-need-help-on-a-build/#findComment-1690877
the cpu cooler will probs come with thermal paste
no ram? :P nice
please tell me you are going to use a 4k monitor with this build
Haha the reason why no RAM is because I was gonna get some RAM off newegg.com that I couldn't find on PCpartpicker. :P I will add that in.
https://linustechtips.com/topic/127107-need-help-on-a-build/#findComment-1692121
Why a Titan Black?
Titan Black was to see how much I could go full out on this build and stay under 3k.
Yes I plan to but memory, I have already picked out some Corsair Vengence LP white edition.
Large PSU is because I plan to SLI in the future and Watercool so I wanted to get a big enough power supply.
The G1.Sniper 5 was because I heard it can SLI 4 cards, comes with a wifi card and antenna, can Watercool the chipset, and is top of the line when it comes to a gaming motherboard. Also because I didn't know if it would be good for media storage, music production, and livestreaming.
https://linustechtips.com/topic/127107-need-help-on-a-build/#findComment-1692137
Build looks fine if you have a 3K dollar budget.
You can get more bang for your buck with a $180 MoBo + 2x 780ti - but sounds like you have deep pockets and price/performance ratios don't matter much.
Only serious recommendations I have, is to stay away from the Titan, and wait for 800 series. And think about what you mean by "future". Don't spend a ton of money on "future plans" with High performance PCs. Your 3K build is going to be obsolete in 2 years. The $1k titan will be given a run for by a $600 card in a year. (But, that's always the case..... :(  )
D3SL91 | Ethan | Gaming+Work System | NAS System | Photo: Nikon D750 + D5200
https://linustechtips.com/topic/127107-need-help-on-a-build/#findComment-1694870
If you really want to have four gpu in SLI you should be looking at LGA2011 socket cpu and X79 motherboards. In which case, unless there is a pressing need, you may want to wait for Haswell-E cpu and X99 motherboards.
In single card configurations GTX 780 Ti perform within the margin of error compared to Titan Black.
https://linustechtips.com/topic/127107-need-help-on-a-build/#findComment-1698685
If you're using pcpartpicker, post the permalink and use the custom part feature.
Also, read: http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/
https://linustechtips.com/topic/127107-need-help-on-a-build/#findComment-1698743
