Budget (including currency): $1600
Country: USA
Games, programs or workloads that it will be used for: CoD, Cs:GO, Rocket League
I put this build together and was hoping to get some feedback on it. Is there anything that I should change about it?
https://linustechtips.com/topic/1270949-help-with-build/
This PC is balanced very well and will be much more than enough for the games you play. I personally would not change anything (at least for the games you play).
But now, fellow gamers, that was it for me. Please keep in mind, that this is just my personal opionion and I am no expert. Your system shall be cooled forever, see you next time.
https://linustechtips.com/topic/1270949-help-with-build/#findComment-14225847
Do you really need that activated windows? You can do all the personalization stuff on windows before connecting to Internet.
Do not get the 3800X, get the 3700X, its almost 40$ cheaper and almost same performance. Do you already have a SSD? Probs wanna get one of that if not. And Idk if you want a ATX mobo, but you can get a B550 mATX mobo thats good quality at cheaper
https://linustechtips.com/topic/1270949-help-with-build/#findComment-14225851
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/1270949-help-with-build/#findComment-14225893
